So, I am building a series of tone generators using 555s. I have 3, all are set to produce a range of freqs between 6 to 500 Hz. All three circuits are situated in parallel with 9vdc on the line. However, I have the outputs going to one common line, for I am trying to mix waves. Each tone generator has a 100K pot to vary the freq. Thus, when all are in a common line, the wave is somewhat funky- it sounds pretty awesome! Unfortunately, there is a problem....
Not all the generators work all the time. Sometimes only one or two work, sometimes none. The problem is weird. If I touch the capacitors coming from pin5, I can often get the vibrator working. Also, if I push on the top of the IC, the circuit will sometimes operate correctly. I'd guess that either the caps are not fully generating or there is some problem with static. I am sure that everything is wired and there are no foul connections, for sometimes the dang thing works alright. I am using an 9vdc trans rated to put out 800mA.
What do you all think? For lack of a wiring diagram I have the following:
555:
Pin1 to gnd; pin2 to pin6; pin3 to out; pin4 to Vcc; pin5 with 0.01uF to gnd; pin6 to pin2, 1uf to gnd, 100k pot; pin7 to 3.3k R, 100K pot; pin8 to Vcc.
I can concoct a visual should it be necessary.
Any help would be tremendously appreciated. Good day all!
Peace!
NVT
555:
Peace!
NVT
