this is an actual circuit that is acutally functioning properly except for the current consumption when pulses stop coming in. I placed a real 1 ohm circuit between the junction of pin 2(input) and the base of the 2907 pnp bipolar transistor. To my astonishment, when pulses stop going into the pin 2 (which is misdrawn as pin 3) my meter reads 78mV across the 1 ohm resistor that goes to the base of the PNP transistor. I can't imagine that there's anything wrong with the transistor, since the circuit works so well. The faulty drawing I made is probably causing endless confusion, pins 2 and 3 swiched, but in real life the base to the pnp (input junction) is at pin 2. When an incoming, a 0 volt pulse hits pin 2/transistor junction, it shorts the timing capacitor (.1 uF) to ground, resetting the timing cycle. So the net effect appears to be that the PNP base, with 12 volts applied, somehow draws 78mA from one of the other leads of the transistor, I'm not sure which. I could use more help with this, and sorry about that drawing. Rich
