555- Delayed Latch Circuit Help
Kalindu Aragorn
Joined May 22, 2018
9
Hello Guys....
I have this Latch Circuit as attached below...
I want to make this Latch after a DELAY. Is it possible?
When powered on, The Relay Activates. What I need is, When you press the push button, The Relay should release after a DELAY which can be set using a Potentiometer. How can I do this?
Thank you.
PS: It doesn't matter if the initial state of the Relay is NORMALLY OPEN. Its just how this circuit works. Its totally ok to suggest a new circuit where the relay is not connected at the initial state, and the push button connects the relay after a delay.
38,952
I can't think of a way to do that without using two 555's or one 556.
Would that be okay?
How do you want to reset the circuit?
Externet
Joined Nov 29, 2005
2,683
I believe pin 3 changes state after a delay from the trigger. If the relay has its other pin to + instead of gnd, it would make a difference. Remember reading somewhere, looong ago, how to modify the 555 circuit so it does not activate at power-on.
38,952
Here's an ON delay circuit using two 555s (or one 556).
The first 555 generates a one-shot pulse width of ≈ R2C1.
The second 555 is configured as a latch that turns on at the end (trailing edge) of the first 555 pulse.
I added a MOSFET buffer to drive the relay as the output current of the 555 is somewhat marginal to directly drive the relay load.
If you prefer you could use a BJT transistor, such as a 2N2222 with a 390Ω base resistor, in place of the MOSFET.
38,952
Here's a delay-on circuit using one CD4013 Flip-flop package, which requires only about half the parts of the 555 circuit.
The delay is approximately 0.7 R5C4.
Turning the power off resets the circuit output to zero.
ocean750
Joined Jul 15, 2020
16
Hello, I am trying to solve a problem using a 555 and I came across this page.
I would very much appreciate if you could have a look at my question.
And also, I would like to run a simulation, seems like your program does that, can you please let me know which program are you using for the simulations ?
Thank you
dl324
Joined Mar 30, 2015
18,524
