Hello
I stripped an ignition coil of a car and have it on the bench. The primary coil has the terminals p1 and p2, the secondary coil terminals being s1 and s2. I believe it is a toroidal core transformer setup.
When I briefly touch p1 & p2 to the terminals of a 3v battery, arcing occurs between s1 & s2 which is what it suppose to do, notice it happened with out using a capacitor between p1 & p2 as it is not the case with automotive ignition systems.
Now I made up a 555 circuit to do the “briefly touch” action of fast on/off of the primary coil current but I can not get the arcing between s1 & s2 regardless of a capacitor presence or not.
The circuit blinks a LED so it should work fine. please notice the circuit attached, the LED and the p1&p2 get connected between the Output "pin 3" and V0 off the 555 chip, the capacitor gets connected between these points as well.
R1 and R2 are LDR
C1 = 47μF
the is a capacitor between pin 5 and V0 of the 555.
Please help me understand why I am not able to obtain spark using the 555 circuit regardless of using 12v or 3v battery.
Thank you
R1 and R2 are LDR
C1 = 47μF
Thank you
