48v DC switch, controlled by 6v using a MOSFET
belaprops2024
Joined Dec 1, 2024
Dear people,
I have a little question how to use the power MOSFET as a switch.
I have an electric bike which has a light connection which is 6v and is switched by the controller.
As I don't want to put stress on the electronics switching this voltage I want to use a MOSFET to have this signal to switch my more powerful lights which work on 48/52v DC.
I found a basic diagram to use a MOSFET as a switch but the resistors are not rated in value. So I was wondering what I should use for Rin and Rgs
I have a IRF540NPBF to be used for this. The rating for the application is well within the specs , as the max current at 48v is 1A and the load is LED
Thank you in advance for your advice
ericgibbs
Joined Jan 29, 2010
21,576
Hi 2024,
I would use a 100R for Rin and a 10k for Rgs.
What is the wattage rating of the lamp?
E
Example: used a IRF530, similar spec to the IRF540 for your application.
DickCappels
Joined Aug 21, 2008
10,661
Those are indeed good values. You can omit RGS if the gate signal is always connected to an input sugnal, but if there is a chance the gate signal can assume a high impedance state, RGS is a good idea to keep the MOSFET off.
