4060 chip for seconds and hours
Dodgydave
Joined Jun 22, 2012
11,395
Build any working circuit, that you know is going to give you the results your looking for, rather than trying to design it yourself, then tweek it to your needs.
Danielpalfrey
Joined Mar 29, 2016
84
I think I'll stick to the solution already posted, it took a while for me to get the grasp of what to do I dont want to have to start the learning process all over again
12,232
I know that you wanted a discrete logic solution but something like is begs to be done via a mcu.
Pish posh... It took a while but I have the timing and decoding down to an elegant solution, one that leads to semi-independent adjustability of the on and off times, with power-on reset, a single 4060, no other gate packages, no uC, and most important of all -- ***no 555***.
The oscillator frequency is chosen such that the half-period of the Q13 output is 6 hours. After Reset, Q13 sits low for 6 hours, then goes high and drives the output transistor through D4. At this time, oscillator pin 10 is low. 5.3 seconds later it goes high. Now both D2 and D3 are reverse biased, and R3 can discharge C2 in a few milliseconds and reset the 4060. This turns off Q13. Since 5.3 seconds is less than the 6 seconds requested, C4 and R4 stretch the output transistor ON time about 2 seconds.
R3 and C2 form a power-on reset timer, and filter any meta-output noise from the diode-AND connection.
To adjust the off time, R1 can be replaced by a fixed and adjustable resistor in series. This will adjust both the on and off times proportionally. To adjust the off time, R4 can be replaced by a fixed and adjustable resistor in series.
dannyf
Joined Sep 13, 2015
2,197
I think you will likely find the posted solutions quite "fragile": it may work well in an airconditioned environment for a few days but once exposed to the elements, or over a long period of time, it may not be able to keep accurate timing - all depends on your needs obviously.
If you can, try to stick to a crystal oscillator if you think it needs to work reliable over a wide range of temperature.
dannyf
Joined Sep 13, 2015
2,197
It should activate for 6 seconds every 6 hours.
In discrete land:
solution #1: find a 1-hr counter, and feed it a 1/6Hz signal;
solution #2: find a 6-hr counter, and feed it a 1Hz signal;
solution #3: find a 24-hr watch, and feed it a 6Hz signal;
solution #4: find a smart phone and set the timer to 6hr / repeat.
GopherT
Joined Nov 23, 2012
8,009
In discrete land:
How do you go from extremely helpful in some posts to captain chaos in another post? Have you even read the OPs posts? Or is this your project? If so, yes, I am happy to report that all of your Solution options will work (depending on what kind of output you need). Danny, If you need verification for additional options for your projects, please open a new thread.
12,232
In discrete land:
solution #4: find a smart phone and set the timer to 6hr / repeat....
None of your "solutions" address the only tricky part of the OP request - the 6 second activation time. Four of your "solutions" still require a very long period timebase clock. In fact, #1 is almost identical to what I posted. I notice that you offered no help in how to "find a 1-hr counter" or "find a 6-hr counter".
Actually, it all depends on the oscillator timing capacitor. +/-10% parts are readily available and cheap, and more than stable enough over the 40C temperature range of a typical home project.
Without getting into bizzaro parts, the lowest frequency crystal is a 32.768 kHz watch crystal, and that isn't even a real crystal. Still, it would need a 30-bit counter to divide all the way down to 6 hours, and the cycle gating becomes much more complex because it locks you into multiples of a 1 Hz period, and neither 6 nor 21,600 are binary increments.
Danielpalfrey
Joined Mar 29, 2016
84
I feel the question I asked originally has been answered. I have to put the circuit together to test to confirm. Sine the timer is to power a propergator it will not be exposed to the elements. It will be nice and snug in a 12 degree room. So I don't fully understand stand how the elements come into play?
GopherT
Joined Nov 23, 2012
8,009
An RC circuit time constant can change with temperature.
Danielpalfrey
Joined Mar 29, 2016
84
I think as stated Earlier the window of free play would make this acceptable? Also. It is indoors so 20 on the thermostat all day? I could use heat sinks to cool more efficiently on the hotter months?
dannyf
Joined Sep 13, 2015
2,197
All of what you are trying to do can be done via a 8pin mcu, with more flexibility.
You may also look into the 4000 family of counters as well.
12,232
No need for heatsinks. The parts in this circuit are not intended to be attached to any kind of thermal management, and there is absolutely no need. Once you stated that the circuit will be operating indoors, all thermal issues with the circuit's accuracy and stability went away. I can go into more detail about why the thermal issue was brought up, and how changes in the air temperature *might* affect the circuit's timing accuracy, but since you have stated some very broad tolerances, none of that matters. I think you should concentrate on learning how the circuit operates.
Also, have you ever programed a microcontroller for a project, or done any other kind of computer programming?
12,232
To program a uC to do this task, you need to know either the assembly language of the uC you select, or C++ (each uC has a variation), or maybe a strange variation of BASIC. You also need a programing adapter. And after all of that you still have to wire up a circuit to drive the motor. It will have 16 fewer total device pins compared to a discrete version, but still... Again depending on which uC you select, there might be a small development board available that has a place for the uC, a prototyping area for the output drive transistor, and a programming interface that talks to a serial or USB interface. Separate from all of that, each uC has its own weird control register structure that defines how each pin functions (input, output, analog, digital, etc.), something I've found to be the biggest PITA in a small project.
Once you are up to speed on a uC and its environment, whipping out small timer projects can be pretty quickly done. But the schematic in post #46 has 37 device pins if you add in two 2-pin connectors for power in and motor out. There is no way that wiring it up will take longer or debugging it will be harder than your first (or even your 20th) microcontroller project.
IMnsHO
dannyf
Joined Sep 13, 2015
2,197
This would be how I would implement it in a lowly 8pdip mcu.
Code:
#define SW_DURATION        (6sec)                //sw on for 6 seconds
#define SW_PERIOD        (/*1hr+30min+*/20sec)    //every /*1hr+30min+*/20 seconds
It is a timer that turns on for 6 seconds every 20 seconds - if you uncomment the code it goes to 1:30:20 just for example.
from a hardware perspective, it is considerably simpler than a discrete solution. Obviously, you will have to learn to code and program a mcu - it took me 5 minutes to get it going.
