so in the picture on the left, the diodes are off?no when the outputs are low the diodes are off, transistor is off, led is off, ...
well, i was close in my reasoning right? i figured out that if i have low the led will be off and if i get high the led will be onHello,
When the input of the diode is low, it will conduct and the transistor can not be switched on.
When the input of the diode is high, it is in reverse connected, and no current can flow through it, the current can go to the transistor, so the led will be on.
Bertus
The picture using the 555 diodes are conducting when the output is low on the 555, this turns the transistors off,so in the picture on the left, the diodes are off?
| Thread starter | Similar threads | Forum | Replies | Date |
| E | 4017 Frustration | Digital Design | 111 | |
| D | HELP WITH 4017 RESET | General Electronics Chat | 29 | |
| O | Using 2 decade counters CD74HC4017 to make it count 20 | Homework Help | 16 | |
Improvement for digital lock project using IC4017 | Homework Help | 15 | |
| K | Decoder encoder using 4017 with IR LED For transmitter | General Electronics Chat | 14 |
