Hi, could anyone recommend a 4-to-2 multiplexer IC that is easy to use ?
Thread Starter EEE_guy Joined Feb 27, 2022 1 Feb 27, 2022 #1 Hi, could anyone recommend a 4-to-2 multiplexer IC that is easy to use ?
ericgibbs Joined Jan 29, 2010 21,569 Feb 27, 2022 #2 hi EEE, Welcome to AAC, Are you having a problem with a particular MUX, that's not easy to use.? E https://components101.com/ics/74hc157-multiplexer-pinout-equivalent-datasheet Last edited: Feb 27, 2022
crutschow Joined Mar 14, 2008 38,807 Feb 27, 2022 #3 What's the nature of the signals you are trying to multiplex?
ScottWang Joined Aug 23, 2012 7,505 Feb 27, 2022 #4 ericgibbs said: hi EEE, Welcome to AAC, Are you having a problem with a particular MUX, that's not easy to use.? E https://components101.com/ics/74hc157-multiplexer-pinout-equivalent-datasheet Click to expand... Hi Eric, I have thought about that ic, but the TS wants to use for an analog circuit, so maybe he could use one CD4052 or two CD4053, we have to wait for the TS to clarify more details that he trying to use for.
Ian0 Joined Aug 7, 2020 13,278 Feb 27, 2022 #5 DG409 if the analogue signal is bigger than standard logic supplies.
ronsimpson Joined Oct 7, 2019 4,811 Feb 27, 2022 #6 EEE_guy said: 4-to-2 multiplexe Click to expand... 2x(2 to 1) ????? 4 inputs two outputs ??? please draw a picture. OR How many address lines. 1 or 2?
