1- Ports In In this task you are required to create a circuit that contains 4 switches (use buttons in the lab). Read values of these switches all at once, treating input as a 4-bit binary number. Display the number in the Serial terminal.
2- Ports out Modifying your previous program, interpret buttons as 2 3-bit numbers, use bit manipulation techniques to split the number into two. Then sum these numbers and display the output as a binary number using 4 LEDs. Use your program to verify correctness of the output. Draw your circuit and write your program on this page. Additionally, show one of the states of your program by drawing state of the switches and LED on your circuit
i need second part of question
