They are also handy if you are not sure if the IC will survive your soldering![]()
If you connect 10 10uF 16V capacitors in parallel, you will have a 100uF 16V with theoreticaly 1/10 of the individual ESR. But maybe 3 or 4 is enough, you need to know what ESR your caps have and what ESR the low-esr types have.So I could simply put multiple 100uf 16v capacitors in parallel to solve this problem?
Usually it's the other guy who runs away.Thank you for the replies.
Yet more questions. No don't run away!![]()
We'll try to keep you on the straight and narrow path here.I am trying to understand why the components working together do what they do; however I am still finding it quite confusing, it makes sense in some ways but not in others. This has not been helped by websites contradicting each other; particularly when it comes to polarity in diagrams.
There are a number of standards, unfortunately. In the early days (I'm talking 1960's when consumers first had access to them), PNP transistors were all in vogue, and schematics were drawn differently. It took a decade or so for NPN transistors to really start catching on. Nowadays, N-ch MOSFETs and IGBT's are in vogue, because it was finally realized that electron flow was far more efficient than hole flow. So, schematics were "flipped" upside down; the polarities swapped and the transistor types changed. I had a hard time with NPN transistors after first working with PNP transistors almost exclusively; I didn't "trust" the "newfangled" things.Some seem to do things backwards. Is it just me or is there a lack of standardized rules when it comes to explaining circuits and diagrams?
Here's just the schematic excerpted from the document:I am working from the 12v desulfator diagram here http://alton-moore.net/graphics/desulfator.pdf .
That's basically correct.If I am correct everything left of the P mosfet is concerned with the 555 which gives timed pulses which tells the mosfet when to conduct.
That's not quite correct.The power comes out the positive red lead of the battery into what will be the top right of the diagram and current goes straight through C4 and charges it and continues through L2 charging that as well while the mosfet is in its non conductive state.
No.When the MOSFET becomes conductive the current from C4 pours into L1 charging the inductor and continues round and goes strait back into C4 in a constant loop.
That's about it. Inductors are like inertia; they resist change in current. Except you're thinking that C4 is a "loop" - it's a capacitor; a place to store electromotive force - like a bucket is a place to store water.When the MOSFET returns to its non conductive state the current in L1 can not continue its loop and resists the change in current causing a power spike to be forced through the D1 diode straight into the negative terminal of the battery at the bottom right of the diagram.
It's OK to have doubt. I hope I've explained it enough so far.I can think of a few configurations in which the circuit may function but the description in the documents does not quite seem logical to me. Where am I going wrong?
See if you can find books by Horowitz; "The Art of Electronics"I am going to the library in a few days to look for some electronics books so hopefully they will help expand my knowledge greatly over time.
The cap is OK. Using caps that are far above the required voltage carries an ESR penalty. You should be looking for caps that are in the 65v to 100v range that are low-ESR.As for the low inductance capacitors I am considering this one: http://uk.farnell.com/panasonic/eee...ssellid=9695958&crosssell=true&in_merch=true& I have read that going to a much higher than required voltage for capacitors is a good idea.
It's probably rather high in ESR, and will not likely be a good candidate for this project.I am been rummaging through my parts and have found a 100uh 400v capacitor that seems to be in perfect condition that may be an alternative despite being a massive. 2.5cm in diameter and 3cm high not including pins.
You shouldn't worry about that. This forum is oriented towards helping "newbies" to intermediate electronic enthusiasts understand circuits better.Thank you for the reply and explination. I was a bit worried I would just get laughed at.
Have you tried reading through our E-books? There are links to the chapters at the top of every page on the forums.It is good to know where I am going right and wrong. Clearly a firmer grasp of how the components work is needed. Well that is for future study.
The voltage across C4 should never exceed 16v. The spikes are isolated from the cap by the 1,000uH inductor.I was thinking that 50v would be more than enough as the schematic stated only a 16v one is needed but seeing as the desulfator gives off 60v It is logical that over 60v is a safer area.
Its' generic name is "magnet wire".What is the technical name of the wire used for inductors that looks like copper with a very thin layer of some kind of insulator? All my searches show up is normal thickly coated wire.
OK, good.I found an old computer power supply and luckily found a 300uH inductor with 0.7-0.8mm enamel wire which should be more than enough for 6 amps. I have finished both inductors now and they both read the exact values I need.
You already had the schematic. What you're doing now is the board layout.All the parts have arrived and I am now drawing a schematic out to decide their best placement on the stripboard.
Perhaps you missed the letters "g", "d" and "s" by the MOSFET terminals in the schematic on the previous page.One thing I would like to confirm is exactly how to connect the P channel mosfet. I have found the information on the data sheet about which pin does what but I am not sure how it fits of the schematic and googling has not helped much.
No. Look at the schematic for the MOSFET pin labeled "s".source would connect to D1 and L1
No. Look at the schematic for the MOSFET pin labeled "d".and drain would connect to the battery positive terminal.
With P-ch MOSFETs, the source terminal is almost always connected to the most positive part of the circuit. When Vgs is less than the threshold voltage, the MOSFET is considered OFF. When Vgs ~=-10v, the MOSFET is considered fully ON.Or source and drain being reversed if the names refer to conventional flow of electricity. Can someone solidly confirm how they should be connected?
That is not an 8; it is a lowercase g.I see that the P channel mosfet has s,8 and d marked on it, which helps a bit.
That is basically correct. If you connect it across C4 with the positive lead on top, that is the same thing.I remember that it was advised to connect my float charger (has not been built yet) with the positive terminal to the battery positive terminal and the negative terminal between L1 and L2.
That is incorrect, and would result in lots of smoke.While researching electronics I have discovered that much of my former knowledge about electronics is incorrect or is lacking in context making things confusing. I used to think that to recharge a battery you connect the positive from the charger to the negative battery terminal creating a circular circuit. This is incorrect isn't it?
They are sort of vaguely related.If so it is blurring the line between capacitors and batteries.
You can add caps in parallel with C4. I added several.Would to be worthwhile putting a bypass capacitor in parallel with C4?
It's not hard. Insert the leads in the holes, and bend at least two of them opposite ways. You don't have to bend them flat against the board, either. Solder the leads, and then clip them off.I have spent the last few hours soldering some of the components in place. I am having quite a bit of trouble keeping the components in place for soldering. I will need to work on that.
It's similar to the font "New Century Schoolbook". They really should have used a sans serif font, but that's neither here nor there.It does look a bit like an older style of writing out a G now that I look at it more closely.
I added several 100uF caps in parallel. This reduces the effective ESR (equivalent series resistance) of the combined capacitors vs simply using a single larger cap or more expensive low-ESR caps.What capacitors did you add in parallel with C4 and what advantages did they give your design?
