Thank you for clarifying.Ah my bad, its 4 devices for the phase current, so 8 per half-bridge, 4 top, 4 bottom x 3 phases = 24 devices @ 60W per device = 1.5kW switching losses approx (5% isn't bad) so you'll need a heat-sink of better than 0.07K/W @ 1440W if all devices are on one sink. You'd be better off using 3 sinks, one per phase, which only need to be 0.21K/W @ 480W, a much easier call.
So I came up with this layout.
8 Mosfet Per Phase so a Total of 24 Mosfet will be used.
Bus bar used in the PCB are 40x9mm for VCC and 40x9mm for GND
40x9mm = 431 Amp + PCB Trace with 35um Thickness will give a current conductivity of 50 amp @35c so Current coming from the Source will be properly managed.
