Can a 3-pole main switch be used to switch 3 different lines at the same time? It's far from a 3-phase feed.
It was then necessary to control 3 different groups from another shield at the same time. Quickly turn on and off. It is not an emergency switch. Can these neutral and defense managers also match?
In theory, can the separate neutrals and protective conductors (belonging to 3 different groups) from the switchboard be connected together at this common main switch, the phases would still remain separate in the 3p-switch?
