3-Pin inductor Question
airplane100000
Joined Aug 2, 2016
73
Given the 3-Pin inductor (small auto-transformer) seen in the image below:
How is it that the inductance between pins 1-2 is 260mH, between 2-3 is 5mH, and yet between 1-3 is 335mH?
One would think that the inductance of pins 1-3, should be 265mH, as both coils are in series. Notice that the windings resistance of 1-3 is in fact 810 (10 +800), as if the entire winding is one big series.
An explanation would be extremely helpful.
-Thank you
Kjeldgaard
Joined Apr 7, 2016
476
Yes, it looks a bit mysterious.
However, it may be something with the square of the number of turns, when it is on the same core.
ian field
Joined Oct 27, 2012
6,536
-Thank you
AFAICR: Mutual inductance is the key, if you wire 2x 47uH RF chokes in series; you get 94uH - if you put the same total number of turns on the same bobbin; you get more inductance than the 2 individual inductors.
airplane100000
Joined Aug 2, 2016
73
I agree. There appears to be an error in the data sheet.
Just curious but what is the part number for the coil?
This is a custom component spec which was sent to me, after I sent that company a similar component I found and asked them to determine its values. For what its worth the part number is LCHB0912-3W-344M.
It is unclear to me how mutual inductance could cause an increase in the total inductance of a coil. Can you possibly provide a reference describing this relationship?
OBW0549
Joined Mar 2, 2015
3,565
You really need to do some math or designing circuits turns out like a monkey with a dart board.:eek:
Very true.
But looking back on 40+ years of designing, mostly analog, it kinda surprises me how little advanced math I actually used. I'd guesstimate that about 5% of the problems I had to work involved very basic calculus, 5% used geometry and/or trig, and the remaining 90% involved nothing more than first-year algebra.
But ALL of the work involved math of some flavor or another. Designing without math would be pure guesswork.
#12
Joined Nov 30, 2010
18,224
I feel a bit of shame to be repeating myself but, I've faked my way through life on nothing more than good algebra and a wee bit o' trig.
The Calculus light bulb never came on for me, but the algebra light bulb did! That's enough for a technician and almost enough for a designer. Some of the guys on here can embarrass me quite easily but I make up for it by knowing my limitations. :D
ian field
Joined Oct 27, 2012
6,536
Very true.
Some people overdo the maths and neglect the science of controlling the electron.
I avoid maths whenever I can get away with doing so - that means more cobwebs to clear when I can't, but I usually get the job done.
The Wireless World magazine was pretty much a showcase of how far the author could fill a page with incomprehensible equations - but they did occasionally publish something useful.
