Vincent Price.Did I miss anything?![]()
(and some of the costumes in his movies).
---Emphasis added---Vincent Price.
What can I say? My silliness quotient seems to be high today.Yet another aspersion cast upon my avatar!![]()
It is expletive obfuscatedwhat is this?
I get mine from my wrecked ULA which crashed cuz piston expanded faster than cylinder and seized up motorfrom where and at what cost you buy it
HP can I get passed that by restriction of the exposure times and duty cycle?In normal operation the anode material coextensive with the 'focal spot' is sufficiently heated to exhibit thermionic emission, and, hence, issue of significant reverse currents leading to rapid destruction of the (relatively) 'delicate' cathode structure... The phenomenon is essentially high-vacuum 'cathode sputter' on steroids![]()
Tell me about itPlease understand,
I know how frustrating it can be when a seeming 'collusion' of equipment design, material properties and economics seem to have you 'blocked at every turn'
Ha ha! Yeah! That's meThings Aleph finds creepy:
-Large bodies of fresh water...
-(Allegedly) Secret Societies...
-Well-appointed execution chambers...
Sadly, NoHP can I get passed that by restriction of the exposure times and duty cycle?
Ok, I get that you, in all likelihood, used the term 'exposure' per force of habit - That said, the demands of 'didacticism' require the following;...exposure times...
Hang in there, my friend!Tell me about it!
ROFLOL!It like parody of Geico ad could say: _If you're a Rotec engine, you seize up, it's what you do!_
Please forgive my intrusion but,U238 burns in a manner reminiscent of magnesium but with production of copious volumes of suspended radio toxic Uranium oxides![]()
Where HP live (USA) unlicensed possession of du is completely legal up to generous limits. I not being sure about here where I live so will check outAre you really going to use this? or will Homeland Security (and several other "alphabet agencies") block access?
I am not qualified to answer you, so you must be addressing HP.I am thinking zn hg amalgam denser than lead so maybe also make good shield for purpose?
Thanks cuz I'm asking anyone with opinionI am not qualified to answer you, so you must be addressing HP.
Hello again,My Shangri-La beneath the summer moon, I will return again
Sure as the dust that floats high in June
When moving through Kashmir
Actually, Aleph is a "Canuck" - and, more to the point, a 'Led Zeppelin' fanHello again,
Are you from Kashmir north india
I'm bound to say U238 is as real as U235 -- albeit many orders of magnitude less expensive!OK. ps, I just figured out you are talking about DEPLETED uranium. Whew! I thought you meant the real thing!
Mercury is only slightly denser than lead prior to amalgamation --- If you insist upon stable isotopes, Wolfram (aka Tungsten) and Gold (each at nearly twice the density of Pb) are your best choices -- Au is easily formed but expensive -- whereas W is cheap but difficult to machine...I am thinking zn hg amalgam denser than lead so maybe also make good shield for purpose?
I meant, "real enough to make nuclear bombs".I'm bound to say U238 is as real as U235
Correct - U238 is fissionable but non fissile...Last I heard, depleted uranium is not bomb-grade.
In all seriousness I think Aleph has a point -- there is (for lack of a better term) a certain 'decency' attendant to 'electrically produced' X/Gama radiation (i.e. bremsstrahlung) - the 'tone' of which is lowered by incorporation of radionuclides in the apparatus - even for shielding purposes --- Tis akin to stocking 'The Vat' with Larry Flynt publicationsBe careful not to glow in the dark, kids.![]()
Ha ha! It not surprising you think that considering it's philosophy I learned to appreciate from you
I confess to to first part, heyActually, Aleph is a "Canuck" - and, more to the point, a 'Led Zeppelin' fan![]()
Um... You do realize the antics to which you refer, assuming they occured at all, happened over forty years ago!?I more fan of music than band cuz all that Mudshark frat boy hedonism no way for Englishmen to behaveI say they need grow up
Hey now! -- While, as in our case, enthusiasm may be shared --- it is not conferable! --- Your genuine, native interest in the subject is amply demonstrated by your rush to hands on experimentation - I hesitate to say "you have x-rays in your blood" lest you perceive said remark as a CML/ALL diagnosisHa ha! It not surprising you think that considering it's philosophy I learned to appreciate from you!
Let me help you with thatI love that tune and Immigrant Song sorry because not know how to attach media![]()
Ha ha! Now you have good pointI hesitate to say "you have x-rays in your blood" lest you perceive said remark as a CML/ALL diagnosisStill...
Inasmuch as exposure time is controlled by switching of the anode supply there's no true parallel -- while 'collimator bugs' is tempting, it ignores back-scatter and tomography systemsHa ha! Now you have good point!So I say best metaphor is one you use before that I'm bitten by the xray bug
Now just light photographer called shutterbug so what that make us
| Thread starter | Similar threads | Forum | Replies | Date |
| Y | PNA Phase measurement is influenced by noise | Test & Measurement | 0 | |
3 phase current limit solution | General Electronics Chat | 5 | |
Patch antenna phased array | Wireless & RF Design | 8 | |
Phase shifter | Power Electronics | 7 | |
| B | Silvaris Garage roller door single phase induction motor | Technical Repair | 4 |
