why is one coil is grounded, doesn't that open the loop ( hence no induction will occur) ?
moreover, why the other coil is not used to power up other loads the same as the non grounded coil ?
in case of a star transformer yes, but in this case of 3 ph generator why ? if it is so, what's the need of the second coil of eachwhy is one coil is grounded, doesn't that open the loop ( hence no induction will occur) ?
First did you or have you done any reading on how alternators, ( it's not a generator) work? Your making AC in this, so you need two field windings for each phase, that is what makes it AC -alternating current.if it is so, what's the need of the second coil of each
phase
by Robert Keim
