3 bit inputs decoder for a 7 segment display
Tohien
Joined Mar 12, 2020
8
Hello everyone, i've just learn encoder/decoder and my homework is "Design a decoder with 3bit input to 7 segment display with Cathode Common then display the character: 9,0,5,b,A"
I confused that with decoder BCD to 7 Segment display we have 4 input and we can display "9" . So with 3 input (3 bit) how can we display "9" and another ?
Thanks you !
Tohien
Joined Mar 12, 2020
8
Have you considered the possibility that "3bit" is a typographical error? Is there even such a thing as 3-bit BCD?
i mean, what is the diffrent from "decoder BCD to 7 segment display" and "decoder Binary 3-bit to 7 segment display" ? BCD we have 0-9 and Binary 3-bit we have 0-7 so how the 7 segment can display "9". Thanks you.
WBahn
Joined Mar 31, 2012
33,260
If the assignment is to display eight or fewer specific patterns, then all you need is, at most, three bits. You are being asked to display five different patterns, so you can't do that with just two bits, so you need at least three.
Imagine that I asked you to design a 1-bit to 7-segment decoder and display 7 and F. Could you do that?
35,227
Your brain is fixated on BCD which stands for Binary Coded Decimal.
Your assignment is not to build a BCD decoder hence get that out of your head.
Tohien
Joined Mar 12, 2020
8
Yah, Thanks for your help!, i don't know how to solve it . Can u show me the hint ?
"binary 3 bits to led 7 segment common cathode decoder to display 9, 5, b, A, 0"
Tohien
Joined Mar 12, 2020
8
thanks you :( i think with 3-bits the 7 segment can display from 0 to 8 right?
djsfantasi
Joined Apr 11, 2010
9,237
Actually, that’s not the problem you’ve been asked to solve. This is the question. With 3 bits input, can you display 5 different patterns on a 7-segment display?
A 7-segment display isn’t restricted to numbers. It is one component with 7 LEDs than can display numbers. Or 128 different patterns.
Note that BCD hasn’t even entered my discussion
WBahn
Joined Mar 31, 2012
33,260
I gave you a hint.
Let's take it a step back even further.
Design a 0-bit to 7-seg decoder that displays the character '7' on the display. Can you do that? Don't overthink it -- wire up a seven segment display so that it displays the character '7'.
Now modify the circuit so that you have a single input signal and if it is a 0 the display shows '7' and if it is a 1 the display shows 'F'. Can you do that? Don't overthink it.
Tohien
Joined Mar 12, 2020
8
I do in this way:
3 inputs X,Y,Z
9 : leds a-b-c-d-f-g on
b : Leds c-d-e-g-f on
A : leds a-b-c-e-g-f on
0 : leds a-b-c-d-e-f on
then i replace "a" acording to X,Y,Z , right?
35,227
No, no, no!
Your values in a-f table are all wrong. Your assignment has nothing to do with BCD!
Erase what you have in the XYX column for now.
WBahn
Joined Mar 31, 2012
33,260
What do you mean "replace "a" according to X,Y,Z"?
What about the pattern that looks like '5'?
You are still stuck on the notion that the inputs represent a number between 0 and 7 and that the display shows that number.
Forget about any link between the number associated with the input pattern and the character that is displayed given that input.
When the input pattern is "011" that does NOT represent a '3' -- it is a particular input pattern consisting of 3 bits. YOU decide which of the seven segments are on and which are off when that particular pattern is applied. It can be ANY of the 128 possible patterns of 7 LEDs. YOU pick what you want it to look like and assign the values on that row of the truth table accordingly.
djsfantasi
Joined Apr 11, 2010
9,237
This is exactly what I was implying in my answer. 11 represents the third SYMBOL; not the number 3.
And note WBahn also referred to 128 patterns. Again, they don’t refer to any specific number, just the fact that seven LEDs can be lit in 128 unique patterns.
Open your mind. Stop thinking about what you think is the solution. It’s not a 7-segment display; its 7 LEDs. it’s not BCD. It’s not a number; it’s an ordinal.
Concentrate on the problem. Not the solution first
