3.7v LIPO Low Voltage Indicator?
arc31
Joined Nov 27, 2016
15
I need a circuit that turns on an led when the voltage of a 1s lipo goes less than 3.3v. Can someone please suggest a circuit that can accomplish this?
Bernard
Joined Aug 7, 2008
5,784
A V comparator with a V ref. on - input, maybe LM385Z, 1.235 V @ 10 uA, or LM336Z, @2.5 V., + battery thru adjustable V divider to + input. Similar ckt. was published on AAC recently, but I do not remember where.
38,669
Here's the LTspice simulation of a simple circuit using the TL431.
It turns the LED on at a battery voltage of ≈3.29V.
Changing R3's value will vary this voltage.
If the LED you select stays on slightly at voltages above 3.3V, add a diode (1N4148 or similar) in series with the LED.
arc31
Joined Nov 27, 2016
15
Can you please explain how this circuit works?
38,669
The TL431 is being used as a comparator.
When the voltage at the control input becomes higher than 2.5V, it starts to conduct.
So the resistor values for the voltage divider consisting of R2 and R3 are selected so that the control voltage is 2.5V at 3.29.V.
Thus the TL431 is OFF at any voltage below that and the LED is ON.
Any voltage above that, the TL431 is ON, which shunts the current away from the LED and it is OFF.
LesJones
Joined Jan 8, 2017
4,521
I too tried the circuit and found that the anode to cathode voltage only dropped to about 1.9 volts when the TL431 was conducting whic was enough for a red LED to still be lit. The forward volyage of a silicon diode is series with the LED made it work as designed. I think the fact that the circuit would always draw about 4 mA could be a problem if it was connected to the battery all the time.
Les.
kubeek
Joined Sep 20, 2005
5,796
I don´t think that a TL431 is a good choice for battery undervoltage sensing as it will needlessly draw a lot of current. There are micropower comparators and undervoltage detectors that will do the job, quite possibly in a single part.
hp1729
Joined Nov 23, 2015
2,304
Les.
Ah, bad choice of LEDs on my part then.
38,669
It depends upon the application and how much the load draws compared to what the TL431 circuit takes.
There certainly are other devices to do the job but how many are as cheap as a TL431 chip?
ian field
Joined Oct 27, 2012
6,536
That's my opinion too - the TL431 isn't exactly "micropower".
Maxim probably do off the shelf battery management chips.
