LiPo battery voltage drop
NickB
Joined Feb 1, 2016
95
Hi there
I'm using a 3.7v LiPo battery to power a variable boost converter outputting 24v. When I connect the battery the voltage on the input and across the battery terminals drops to 1.9. When I switch it off, the voltage goes back up to 4.1v. I'm using a 1100mAh battery, the output side on the boost converter is drawing approx 500mA and is used to saturate a couple of 35v caps to drive a coil.
I suspect a protection circuit on the battery is kicking in if it thinks too much current is being drawn. My question is - is there a simple fix?
Any help or advice is greatly appreciated.
BobTPH
Joined Jun 5, 2013
11,662
You are asking the battery to supply more than 24/3.7 x 500 = 3243 mA
A Lipo battery that is not a high-discharge type can only supply about 1C = 1100mA.
The result is not surprising.
38,868
If you are just charging capacitors, the add a resistor in series with the converter output to limit its output current to about 150mA.
NickB
Joined Feb 1, 2016
95
Thanks for your reply. This is the boost module I'm using: https://www.amazon.co.uk/dp/B091YQRZPL?ref=ppx_yo2ov_dt_b_fed_asin_title
The max current the boost converter can supply on the output side is 2A, however, that's at a much lower voltage. At 24v it's drawing much less so I would have thought the battery could cope. Bigger battery or AAAs I guess.
BobTPH
Joined Jun 5, 2013
11,662
The current rating of a power supply only tells you what it can produce continuously without being damaged. Generally, they can provide higher currents for a short time, but won’t last long if you do that.
NickB
Joined Feb 1, 2016
95
Understood. Thanks
38,868
If the capacitor charging speed is important, you could use a simple two-transistor constant-current circuit instead of a resistor to limit the charging current, but reduce the charging time by a factor of about 3 to the 90% capacitor voltage value.
NickB
Joined Feb 1, 2016
95
Thanks for the additional info. Just added a 120-ohm resistor in series to the output. Worked a treat!
