3.5v 8 bit DAC circuit to drive 25ohm load
tom66
Joined May 9, 2009
2,595
Replace LM741 with an LM324 or similar op-amp which can go to ground, or use a -12V supply. Find an op-amp which is capable of sourcing the required 200mA. (A power op-amp.)
SgtWookie
Joined Jul 17, 2007
22,230
Your resistor network of R2 through R9 should be more like an R-2R ladder. Google that name and see what you find.
The opamp is connected improperly. Look up "non-inverting amplifier". Since your input range is 0v-3.5v and you require an output of 0v-5v, you will need a gain of ~1.4286.
The 741 opamp is not rail-to-rail, so you will need a negative supply as well as a positive supply. This is also true of your Q1/Q2 current amplifier; it won't reach the power rails.
However, you have Q2 connected upside-down, D1/D2 are shorted out, R15, R10 and R11 should not be there, and your opamp needs to take its' feedback from the junction of the Q1/Q2's emitters.
ErnieM
Joined Apr 24, 2011
8,415
Q1 & Q2 look like an attempt to make a push pull output stage, but this app only requires a push amp; if the feedback of the amp comes from the emitter then the b-e drop can be removed as an error term.
radetonator
Joined Aug 1, 2011
50
Yes. It's a R/2nR DAC with buffer to drive 25 ohm load.
The circuit has been changed. But output could only reach 3.1V.
What should be done?
tom66
Joined May 9, 2009
2,595
Change the R17/R13 pair to 5k/20k and ditch the LM741 as it will not be able to output below about 1.5V which will keep the transistor switched on. Use an LM358/LM324, or even better, a modern RRIO op-amp such as MCP6002 (available for around 20 pence.)
SgtWookie
Joined Jul 17, 2007
22,230
You don't need U2.
The 741 is OK if you have a dual-rail supply, which I see you have done.
5 Ohms and 20 Ohms are far too low of a resistance for feedback to the opamp.
However, you did not pay attention to my statement that you needed to use a non-inverting amplifier with a gain of ~1.4286.
Here is a page on non-inverting amplifiers:
http://en.wikipedia.org/wiki/Operational_amplifier#Non-inverting_amplifier
Note that the simplified formula for gain is:
Vout = Vin(1+(R2/R1))
I suggest that you start by using 43k for R2 and 100k for R1.
Also, you are taking the feedback from the wrong place. Instead of taking the feedback from the output of the opamp, take it from the emitter of the transistor.
ErnieM has a good point in that a push-pull current amplifier is not required.
SgtWookie
Joined Jul 17, 2007
22,230
The page you referenced shows an inverting summer. You said you need an 0v-5v output, which requires a non-inverting configuration.
Try it with the non-inverting amplifier that I linked to in my previous reply, with 43k for R2 and 100k for R1, the output of the amp to the base of the transistor, and the feedback from the emitter instead of the opamp output; this last part means that the right side of R2 needs to connect to the transistors' emitter instead of the opamp output.
SgtWookie
Joined Jul 17, 2007
22,230
That's looking MUCH better.
Did you check to make sure that the gain of the opamp is now proper?
Did you notice that you are exceeding the power limitations for Q1?
Do you have any ideas how you could reduce the power dissipation in Q1, without changing Vcc?
radetonator
Joined Aug 1, 2011
50
A resistor connected to the collector is needed? Then change the gain of the opamp?
SgtWookie
Joined Jul 17, 2007
22,230
If you insert a resistor in series with the transistors' collector, it will help to take the power dissipation away from the transistor.
Assuming that the output of the opamp can go no higher than the supply voltage -2v, and that the transistors' emitter will always be at least 0.7v less than the base voltage, how much resistance can you put in series with the collector without affecting the desired current through the load?
No, I asked you if you checked to make certain that the opamp gain is correct.
Start by putting 0v to the non-inverting input. What is the output voltage that you read on the transistors' emitter?
Then put 3.5v on the non-inverting input. What is the output voltage that you read on the transistors' emitter?
radetonator
Joined Aug 1, 2011
50
A 20ohm resistor is added to collector. But BD139 has maximum power of 12W. i think without the resistor is still ok?
The simulation shows that output is 5v. Anything wrong of this circuit? Thank you.
SgtWookie
Joined Jul 17, 2007
22,230
You should be able to go up to 33 Ohms with R12.
It should be rated for at least 2 Watts.
I don't know what you're doing with all of the resistors and voltage sources on the left, but that's OK. If it works for you, that's fine.
radetonator
Joined Aug 1, 2011
50
It's a DAC circuit which converts 8 bits 3.5V TTL into 0-5V analog voltage.
Thank you
radetonator
Joined Aug 1, 2011
50
The circuit has been modified. For the R-2R ladder, should the value of the resistor be 1K and 500ohm enough? The digital signal is driven by the NI data acquisition box.
SgtWookie
Joined Jul 17, 2007
22,230
I don't know what the current source/sink capability of the NI data acquisition box is.
If the DAC is entirely contained within the NI box, then you don't really have to worry about it, as the opamp will have a fairly high input impedance and won't load the analog signal much.
If the NI box output is digital, then you should increase your resistor values very significantly. I suggest using 10k and 20k, as they are standard values that are easy to obtain, and won't load the digital outputs very much. However, you may need to use an opamp with a much higher input impedance to get accurate results, like a TL071 or newer JFET-input opamp.
radetonator
Joined Aug 1, 2011
50
so LM324 needs to be replace by TL081? i have tried the circuit,which is very unstable. sometimes output was 5V,sometimes was 3.6V. :(
