3.3V source for esp8266 lm317 vs lm1117
quique123
Joined May 15, 2015
405
so I need a power source for a 3.3V Esp8266 which is gonna be connected to a dht22 to report temp Data to a server. I've got the code up and running, just need to throw in a esp wdt.
Looking for a standalone power source I was first suggested an MCP1700. For some reason I posted about it in the Arduino forums and was suggested a lm1117 instead because of the quiescent current superiority.
So I'm ordering it but I remembered I had other voltage regulators and indeed found:
Some lm7805 which I know are for 5V
Some amc7135 which is a current regulator
Some lm317, which are variable voltage regs. Could I use these? What would be the pros and cons vs the lm1117?
38,855
The main difference is dropout voltage.
It is 1.2V for the lm1117 and about 3V for the LM317, so it depends upon the supply voltage that powers the regulator as to which one you can use.
The LM1117 would require a minimum of 4.5V supply voltage (allowing operation from a standard 5V supply). and the LM317 a minimum of 6.6V.
quique123
Joined May 15, 2015
405
OK here's why u thought what I said:
The lm1117 would require 4.5V to supply 3.3V (1.2v extra) vs the lm317 which would need 6.6v (3.3v extra).
