single 5V power source for ESP8266
jamesbowers
Joined Feb 18, 2019
Hi all
I am using an ESP8266 NodeMCU to drive a set of 7 relays.
The NodeMCU is a 3.3V device but can take 5V power via a USB plug.
The relay board can take the 3.3V pin logic as input but uses a 5V supply to power the relay coils. LOW = on.
Each relay can draw 70mA and I will usually only ever have 4 on at a time, but when the ESP8266 boots it lowers the signal on 6 of the pins so I could reach 420mA draw for the relays.
I have a 5V power supply that is rated for 550mA so this sounds perfect. What I want to do is power both the ESP8266 and the relay board with the same power supply.
Is there any risk to simply running the +5V and GND into the USB socket and to the relay board terminals?
Andrei Suditu
Joined Jul 27, 2016
52
Well you may experience transients from relay switching.You can try and see if switching 4 relays a a time reset the nodemcu.
If it happens put a 10uh-33uh and a cap to form a basic LC filter for the NodeMCU.
Relays are powered raw while the nodemcu from the LC filter.
Find a the LC filter schematic on wikipedia.
It's a low pass filter that should keep transients away from the NodeMCU.
I'd use 2 caps.1 beffier of 470uF or around that value,and a second ceramic one...if available around 1-10uF.(helps with HF noise and has a better ESR).
