3.3V Microcontroller pin protection circuit.
Dusan123
Joined Aug 7, 2023
5
Hey all! :)
I was looking for a solution to protect the analog pins of the ESP32 microcontroller. My circuit can produce voltages up to 5V and the analog pins of the ESP32 can only withstand 3.3V max.
I found a solution online (picture attached) but I don't understand how the circuit works. I tested the circuit in LTspice and I don't get expected results.
Can you guys check if the circuit even works and if it does can you explain to me how and why?
Thank you!
AlbertHall
Joined Jun 4, 2014
12,663
Providing the opamp can sink at least as much current as your circuit can provide it should work.
If the analog input goes more than 3.3V positive then there is negative feedback via the diode which will limit the output to that value.
If your circuit is able to produce a lot of current then you could put a resistor between the analog input and your circuit.
Dusan123
Joined Aug 7, 2023
5
Aaaah I see, now I understand. Thanks man!
Ian0
Joined Aug 7, 2020
13,317
It would be really useful to know how the ESP32's GPIO protection circuits are arranged. For a proper microcontroller, that information would be in the datasheet.
In the absence of that information, place a schottky diode between the pin and Vdd, and a current limiting resistor about 1k.
Jerry-Hat-Trick
Joined Aug 31, 2022
863
What is wrong with a voltage divider?
You mention analog pins, so presumably you are using the pins the covert signals up to 5V into digital? The ESP32 is surprisingly non-linear near to 3.3V input, so I'd use a potential divider to drop the maximum of 5V to around 3.0V. In case you are not familiar with the concept, try connecting your sensor output to a 10K resistor, in series with a 15K resistor to ground. The maximum voltage at the point between the two resistors will be 3.0V. The processor itself has an input resistance, so you may get slightly less than 3V but you probably won't notice and it's best to calibrate (and scale) sensor values anyway..
28,595
I suggest using a series resistor to limit current and then a diode clamp circuit with the top voltage set to limit the input to the actual acceptable maximum.. The opamp scheme is likely to be rather non-linear, and that would limit the accuracy.
