28AWG Wire Splice Ideas?
newothegreat
Joined May 3, 2012
26
I just received some custom components that have short wire leads coming off them, and it turns out the leads are about 5mm too short. I need to add a short length of wire onto the end of the leads to extend it. The wire needs to be able to bend in a few different places, so I can't solder it since it would be too brittle, and the solder would wick into too much of the wire, preventing it from bending where I need it.
My plan was to splice the two wires together using a very narrow crimp band, so that the wire could still bend where I needed it. After a few hours of searching, I could only find one part that seemed like it would work, but the crimper and applicator were all together around $13k, which is too much for this rework job since I'm only going to need it for a couple hundred crimps. This is the part:
https://www.digikey.com/product-det...y-amp-connectors/63621-2/A111513CT-ND/4142899
Does anyone have any suggestions?
-Crimp wire splice
-2x 28awg wires in a "thru-splice" configuration
-preferably 2mm wide (in the direction of the wires)
-inexpensive tooling hopefully
Thanks,
Owen
newothegreat
Joined May 3, 2012
26
That's how they get you. They'll charge you 10 cents for the part, but $10k for tools to make it work.
That component is the kind of thing I'm looking for, but it's too long for what I need. It's a about 12mm long, and I need it to be 2-3mm maximum.
38,561
Don't know if they make anything that small.
Could you cut them to the length you need?
dl324
Joined Mar 30, 2015
18,395
  1. Put the solder joint in a place where you won't need it to bend.
  2. Replace the entire wire instead of splicing.
newothegreat
Joined May 3, 2012
26
Thank you for the replies, everybody. Unfortunately I do not have much space to work with, since the lead coming off the wire is only 14mm to begin with. I can't really add in a solder splice where it won't need to bend - almost the entire length of the wire needs to bend! Also, there is no room to add an additional wire loop.
The wire leads are integral to the components, and are potted in epoxy, so there really no way to replace the wire leads without destroying the component itself.
$13,000 definitely is a lot of money for a crimp tool, but it's not a completely outrageous amount of money. The only tools that can crimp that particular splice band are high-end automated crimp tools used to high volume production. It's at the high end of the cost spectrum, but not completely unreasonable (after all, some companies are buying them...).
What I was really after, was to see if anyone had a suggestion for a similar crimp band that could splice together two 28AWG wires, and was as small as possible.
Thanks again.
Alec_t
Joined Sep 17, 2013
15,125
1mm bore copper/brass tube (from old bulb-type thermostat?) cut to 1.5mm lengths. Solder will be drawn into it by capillary action and remainder of wire would remain bendable.
strantor
Joined Oct 3, 2010
6,875
