Do you have two probes for the oscilloscope?Picoscope 2204A
10Mhz bandwidth
Slow down!I'm now by both boards installed,
Couple more discoveries, green led on good board is solid.
On bad board is flashing, seems to be driven via a 74hct04 inverter from a max 692 which is a processor supervisor?
The whole circuit is clocked by the special bus driver chip ams3609, clock signal is present at the processor xtal pin.
I need to read up on the max692
Sounds like fun!Thank you, there's going to be a brief (hopefully!) Break while I recover my pickup from the ditch my workman put it in (really)
I appreciate the time
Cheers Geoff
