25A Relay for fan control
ErnieM
Joined Apr 24, 2011
8,415
I'm trying to help someone out on Quora. They need to switch a fan running off a 120V/25A service, and wish to use a smart switch.
Now such switches don't exist, but those that do could easily switch a relay that does the heavy lifting. I just do not know how one would do this and still be safe and to electrical code.
Would anyone have a thought where I could point him?
MaxHeadRoom
Joined Jul 18, 2013
30,663
Anything over 50v has to be in a recognized enclosure with correct circuit protection, fusing etc and all metallic surfaces be earth grounded.
The nature of any low voltage supply also has to be known.
Max.
wayneh
Joined Sep 9, 2010
18,105
Is everything else in place, a 25A circuit with a breaker? Not that I have a solution, but if that’s not in place then there are bigger problems.
ErnieM
Joined Apr 24, 2011
8,415
Max.
That is a given. From what I know one may not simply piece together components, even those listed, without the overall component also being certified.
Meaning I can get a metal box to hold a relay, wire and ground it, use BX cables and such, and still have a non code compliant unit. That is why I did not recommend this approach to him, though I may do such in my own home (but have not).
I'm not quite sure if the terms here it has been a few years since I was investigating such equipment building (low voltage solar power for an isolated light house).
A listed enclosed relay would be a great find.
wayneh
Joined Sep 9, 2010
18,105
The closest commercial product I can think of is used in home theater, where a 12v signal can be used to turn on various components. Even that’s not common and I can’t imagine a 25A rating.
Every smart switch I’ve seen tops out at 15A.
ElectricSpidey
Joined Dec 2, 2017
3,335
Any off the shelf home automation system that can turn on and off an appliance could be modded to turn on and off a relay instead, and done up to code with no problem.
The trick really is the interface between the smart switch 120 volt output and the relay enclosure, nothing Mickey mouse here.
If you don’t know how to comply with the codes in your area, then this is not a project for you.
38,515
How about a 5-12Vdc output wall-wort plugged into a smart-switch, with the wall-wort powering an SSR.
That way the only external high voltage is the fan connection going to the output of the SSR.
ErnieM
Joined Apr 24, 2011
8,415
Unfortunately, once you modify a listed item it is no longer usable in any system that must pass NEC code.
Fine, except how does one mount a SSR to code within a structure? The guy I'm helping here is running a roof vent fan or such. Not a box on a table connected with a power core (which does not have to follow NEC code) but hard wired into his building, which needs meet NEC code.
BR-549
Joined Sep 22, 2013
4,931
What exactly is a smart switch. Does it have an ip address? There are wireless motor control contactors for 25 amps at 120 V. Code rated.
wayneh
Joined Sep 9, 2010
18,105
Yes, but only on the LAN where it resides. The means to access them from the WAN vary. Some devices require a local hub or a website to handle the security aspects of connecting remotely. It's an IoT switch.
ErnieM
Joined Apr 24, 2011
8,415
I have controlled my smart devices from the next county.
Yes, it does depend on the code behind them. In this case, the app on my phone knows the IP in my house and sends the commands as needed.
Would you have a source or part number? I spent some time looking for one but lack the magic key words.
