Which type SMPS do you recommend?I suggest you investigate other/different switch supply topologies.
Here is a basic tutorial on several types of DC-DC converters:Which type SMPS do you recommend?
That switching speed is definitely possible, but achieving the speed, power, voltage and current you specified is difficult.Is Switching a power mosfet possible at 250 kHz under 30 A rms current?
Do you have any experiment on this issue.
I want to design a boost converter
Vin=24
Vout=280
P=700W
f=250 kHz is possible for switching.
