panic mode
- Joined Oct 10, 2011
- 5,427
that is exactly what i've been saying.
When the ULN2003 arrived on the scene 40 years ago, it had the diode built in!that is exactly what i've been saying.
One great thing about AAC is learning about new ICs that I would never have thought to look for.yes, and things changed a lot in 40 years. modern ICs pack way more punch. for example
https://www.infineon.com/dgdl/Infin...N.pdf?fileId=db3a304320d39d590120f700bb736a89
I came here to ask a question about a flyback diode on the coil of a contactor and the thread was rapidly hijacked into why suppression was required across the load. The signal to noise ratio made it hard to figure out the answer to the original question.this is a public forum and everyone is entitled to their opinion.
... snip ...
btw. why stop at one interposing relay per output? you can have several of them driving each other. if you play your cards right, you can get kickbacks from the relay company![]()
Actually, it's quite important to know whether the suppression should go across the driver or across the load.why suppression was required across the load.
