24 volts DC @ max 2.5 Amp from Computer PSU
anaalmansuri
Joined Jan 5, 2019
Hi Guys,
I am wondering if it is possible somehow to get 24 VDC from a computer power supply to provide supply to Programmable Logic controller?
Please give ideas?
Thanks!
KeithWalker
Joined Jul 10, 2017
3,612
Hi Guys,
Please give ideas?
Thanks!
Most desktop computer power supplies have a +12V and -12V DC outputs. That is 24V between the two. NOTE: If it is used in this way, the supply common must not be connected to ground if the -12V is connected to the PLC ground. The maximum current output on the +12v supply is somewhere between 4.5 and 18 amps depending on the model but the -12V supply is only rated at 1/2 to 1 amp. This will limit the current you can draw between the + and - supplies. The ratings for the different models are listed here:
http://web2.murraystate.edu/andy.batts/ps/PowerRatings.htm
