220V DC Power Supply in North America
Mr. Multimeter
Joined Sep 17, 2018
68
I purchased (accidentally) a Power Supply that is rated 220V (non switching), from a vendor on Ali...I was unaware it was a European 220V input, It has worked flawlessly on 120V AC, no ripple or noise, solid and stable....how is this possible??
MaxHeadRoom
Joined Jul 18, 2013
30,868
Many SMPS power supplies will operate across quite a voltage range, the crunch will probably come when you try it with the rated current.
Max.
rsjsouza
Joined Apr 21, 2014
430
As others have said, these switching power supplies can use a wide range of input voltages. Maybe the seller was advertising as 220V to cater a specific market - who knows?
Just tried it, no problem, brought it to the 6A limit and displayed at 6.00A spot on ...???
Keep it running at maximum output for some time (half hour? one hour?) and monitor it closely to avoid any nasty surprises.
