2 voltage sources neither in series or parallel
patrickbryanbedard
Joined Mar 4, 2022
14
I'm taking a circuit analysis class and struggling with the circuits that have two voltage sources (which aren't series or parallel) I know the rules for series and parallel. I have already solved/worked my way backwards from the answer in the book on this problem. I would like to verify the answers by using Ohm's law. Does anyone know how I would get RT and ET?
patrickbryanbedard
Joined Mar 4, 2022
14
If RT and ET are the Thevenin equivalents for the voltage source and resistance, what circuit node do you want to use for the reference point?
So we haven't got that far in the class have not covered Thevenin or Superposition. Maybe I will read that chapter. Do I have to pick a point? Couldn't I just solve for the entire circuit? Etotal and Rtotal? There's 35mA flowing into the drain.
WBahn
Joined Mar 31, 2012
33,135
What are RT and ET?
You need to define your terms.
If RT is a resistance, what is it the resistance of? Looking between which two nodes?
If ET is a voltage, it is the voltage between which two nodes?
If this is a problem that you have been given in your class, then the expectation is that you have covered enough material to be able to solve it using what has been covered.
What, precisely, is it that the problem is asking you to solve for?
Show your best effort at working the problem as far as you can, based on what you have covered. That will give us both some idea of what you have and haven't covered and also what your line of reasoning is. We can then tailor our hints and suggestions to help you progress.
patrickbryanbedard
Joined Mar 4, 2022
14
What are RT and ET?
RT= total resistance of the circuit
ET= total voltage of the circuit
So far we have done OHM's law, series, parallel and combination circuits. In the most basic circuit using OHMS law you can find E total, I total, R total with a little information. So I guess I just want to know the total circuit resistance for starters.
WBahn
Joined Mar 31, 2012
33,135
When you have simple series/parallel combinations of sources, you can reduce the sources to a single source. Then the "total resistance" you find is the resistance AS SEEN by the effective source. That single effective source is your reference.
But when you have more complex circuits, there are many choices for what the reference is and you need to specify what reference you want because the results are, in general, different for each.
Again, what were you tasked with finding for that problem?
patrickbryanbedard
Joined Mar 4, 2022
14
You are a hard learner. :rolleyes:
Again, it depends upon which node you use for a reference point.
Is that difficult to understand?
Yes I do understand that voltage is a potential between two points so let's just forget about the Etotal for a minute. What is the total circuit resistance (RT)?
for instance: in this circuit RT(total resistance)=R1//R2//R4+R3= 19.99666722 ohms
patrickbryanbedard
Joined Mar 4, 2022
14
patrickbryanbedard
Joined Mar 4, 2022
14
This is the exact problem although as I mentioned in my original post I have already solved the HW (problem below). I'm trying to verify that my answers are correct by solving in a different fashion.
WBahn
Joined Mar 31, 2012
33,135
That is the total resistance SEEN by the source.
With simple circuits like this, asking for the total resistance IMPLIES that you are asking for the total resistance as seen by the source.
But you could also ask for the resistance as seen by R2. Or R4.
Once you have a circuit that is complex enough that it is not obvious which component is being used as the reference, you must specify that.
WBahn
Joined Mar 31, 2012
33,135
You said that you solved it by working backwards from the answers in the book. That's not solving the problem.
If you hadn't had access to the answers, could you still have solved it?
How would you have done so?
If you would have done it using loop voltages, the solve it using branch currents. If you would have done it using branch currents, then solve it using loop voltages.
The problem as given is not properly defined. It asks you to find two currents, but doesn't define what the directions of those currents are. So be sure to define those for your solution.
patrickbryanbedard
Joined Mar 4, 2022
14
So how can I verify this or solve in another way?
38,764
Once again, that's from a particular node (in this case the one connected to V1).
So what's the node you select for your homework circuit?
If it's from a source, then there are two sources nodes, take you pick.
Is that clear?
RoofSheep
Joined Mar 7, 2023
36
You know Vb = 60V. You can now calculate the current through the 8k resistor. You can also calculate the current through the series combination of the 10k and 5k resistors. Use this current to calculate Vc. Now calculate Vab and then I1. Rather use basic principles than forcing the circuit to look like somethings that you are familiar with.
