2-transistor buck circuit
DickCappels
Joined Aug 21, 2008
10,661
Where is says "Q3" try reading it as "Q2" and I think it will make sense.
Alternatively, here is an excerpt from U.S. Patent 6,603,342 B. It is the same oscillator only the PNP and NPN have switched roles. The circuit lights a LED from a 1.5 volt battery. This circuit has been around for more than 50 years, yet the inventor was granted a patent in 2003. Maybe that's because there were no LEDs in 1960.
Frank@Frank
Joined Jul 24, 2021
23
Hi!
Say I want to design a 10-30V input voltage and output 9V 200mA, how should determine each components value and the switching frequency.
BTW, circuit can be patented?
35,324
This is your basic PNP-NPN relaxation oscillator. It should work. V1 can be almost any voltage 2-12V.
Change C1 for desired frequency.
