That's $6 less than the cheapest I found this morning...itead
10 boards 10cm x 10cm for $19.90 USD..
can't beat that..
http://imall.iteadstudio.com/open-pcb/pcb-prototyping.html
quality is great.. took about 2 weeks to make it to the US after I placed the order.
If you DIY you don't need rivets or anything.. the component leads will work just fine as through holes.. just solder them on both sides.. then you can just use a piece of cutoff leads from a resistor or whatever to make any vias you need.
yep the $19.90 is for all 10 boards (not each) all drilled/silkscreen,etc... and they do a really good job at it..Sorry for the confusion mcgyvr, and thanks for the post... I can barely believe they are going to print and drill 10 boards for $19.90.
Is it ok to route power trace under RF network if its 3 layers away? | Analog & Mixed-Signal Design | 2 | |
Selecting components in 2 layers | PCB Layout , EDA & Simulations | 0 | |
| E | High speed signal routing layers | PCB Layout , EDA & Simulations | 15 | |
| E | PCB layers | PCB Layout , EDA & Simulations | 17 | |
| M | Help OSI model layers | Microcontrollers | 30 |
