2-bit binary counter ic in proteus
dl324
Joined Mar 30, 2015
18,453
Welcome to AAC!
can anyone help me to find an ic for 2-bit binary counter ic in proteus??
Are you referring to a commercial IC? They don't make 2 bit counters, but you can use a 4 bit counter and only use the two lower bits.
Do you want synchronous? Or asynchronous?
Papabravo
Joined Feb 24, 2006
22,116
You can easily make one from a pair of flip-flops.
Hint: If you have a JK Flip-flop component it could not be easier.
Figuring out what is inside the 2 Bit Counter subcircuit is the challenge.
