+2.5/-2.5 V Voltage Divider CAD Doubt
giovannelucas_
Joined Jan 5, 2023
39
Hi everyone,
I'm trying to design a voltage divider to power op amps. However, I'm in doubt if my schematic layout is correct as it uses 5V power from an Arduino instead of a double cell battery.
Please find my schematic below.
Another question is, for homemade etched copper pcbs with Perclorete. What should the trace width for power and signal be? 0.3mm for signal and 0.5 mm for power or 1 mm for both? How does eletromagnetic interference play a role in building noise in precision analog or digital signal applications?
Thank you.
dl324
Joined Mar 30, 2015
18,521
As drawn you have problems. You have both ends of the voltage divider connected to 5V. If you ever connect GND in your schematic to ground for the Arduino, you'll also have problems.
Instead of showing us your proposed solution, why don't you tell us what you're trying to accomplish?
38,945
Why do you think you need a dual supply?
Often you can use op amps with a single supply, and just offset the signal to the middle of the supply voltage.
What op amps do you intend to use?
Can they operate from 5V?
giovannelucas_
Joined Jan 5, 2023
39
Hi @dl324, I'm building an ecg amplifier. So the circuit needs to operate between +2.5V and -2.5V in order to reflect the negative parts of the ECG form. Right?
giovannelucas_
Joined Jan 5, 2023
39
Hi @sghioto,
Sorry for my question, How do I draw that 5V + and - symbol on Kicad? Is it on the power library or symbol library?
You're right about C5, I didn't realize the polarity was wrong.
WBahn
Joined Mar 31, 2012
33,342
Your resistors need to be size so that your midpoint stays close enough to the desired midpoint voltage under the maximum current that it will need to support.
dl324
Joined Mar 30, 2015
18,521
But when I go layout the board the OPAMPS still show powered by +5V and GND.
Are you measuring with respect to what you've called the Arduino ground? Or your virtual ground?
If you measure between the V+ and V- pins of the opamp, you'll measure 5V. If you measure with respect to the virtual ground, you'll get 2.5V on V+ and -2.5V on V-.
giovannelucas_
Joined Jan 5, 2023
39
Hi @sghioto, it's because I don't know how to draw that +5V with a green wire and + and - poles. I searched but didn't find that symbol. Would you mind showing me how to draw that symbol?
dl324
Joined Mar 30, 2015
18,521
the Arduino ground
Since you're "generating" the negative voltage from the Arduino supply, you can't have a negative voltage with respect to Arduino ground.
It should show +2V5 and -2V5 on the pins when I go layout on kicad.
Voltages are relative to whatever you're calling ground. You can have -2.5V relative to your virtual ground, but you can never connect your virtual ground to Arduino ground.
giovannelucas_
Joined Jan 5, 2023
39
Hi Dennis, thanks for the clarification. I understand the concept of the relation of voltage and ground, however, I don't know how to draw it on a schematic for a PCB. Do you have any schematic examples?
dl324
Joined Mar 30, 2015
18,521
Your virtual ground is just another net in the schematic. You can use any net name you want, but using GND will cause confusion, while Va wouldn't. You can avoid even more confusion by not using the ground symbol to represent it.
giovannelucas_
Joined Jan 5, 2023
39
Hi everyone, I decided to change my power supply to a 9V battery (+4V5 and -4V5) as the OP AMPS can handle it and it's easier to layout on the schematic.
Thanks for the help everyone. I have to study more about virtual ground.
