I'm making a project where it will be hard to take the batteries in and out, so I want to build an on-board charging port. I'm thinking of just adding two connectors to the BMS output, One for Charging and one going to the circuit. My concern is if the circuit will get damaged while charging is going on. Do I need any other protection between the BMS and the circuit?
Minor question: For purposes of space, I'm thinking of adding my power switch between the battery and the BMS. Is there any reason why I shouldn't do this?
Batteries: 3x18650 cells.
BMS: Cheap BMS I'm using mainly for low voltage protection, I will be charging with my balance charger (Tenergy).
