170 VDC Output
Coucou80
Joined Apr 7, 2018
78
I recently purchased a SOLA Ferroresonant tranformer that provides a 170VDC output (confirmed with oscilloscope and 10x dividing probe).
The devise is bulky and weights about 25lbs. The device is comprise of a bulky isolation transformer and its 660v tank capacitor. Mains leads to primary and secondary leads to another 1500MFD 200V Cap with a bulky 2K resistor that gets realy realy hot when the device is powered!
My question:
How can it output a 170vdc without a diode bridge??? The above listed parts are the only one that I can see.
Best regards.
Coucou80
Joined Apr 7, 2018
78
You are correct ... typo on my end.
From what I can see from the visible parts I can only see a resistor a capacitor and the transformer’s tank circuit capacitor. Would it be possible that the diode bridge is inside the transformer casing?
It looks like a set of four rectifier diodes near the terminal strip. From the bottom view I can see a bleeder resistor for the filter capacitor.
MaxHeadRoom
Joined Jul 18, 2013
30,884
It normally runs hot because it runs in saturation mode, any load takes it out of saturation to a degree, this is how it regulates, they are not very efficient!
Max.
