12V Signal to 24V Switch
Goerge99
Joined Mar 18, 2008
3
Good day.
I wonder if anybody out there can help me out.
I have a 12 Volt signal coming from a field device into a PLC.
The problem is, the field device is a 12 volt signal, and my PLC is a 24 volt.
How can I get a 12 volt signal to switch a 24 volt signal?
Is there any clever, yet easy way of doing this?
Thanks for your Help.
Goerge99
Joined Mar 18, 2008
3
I have tried to switch a 24 volt supply with the use of a diode, and a 9 volt battery.
But I can seem to get it correct, nothing happens. The diode doesn't even blow...
KMoffett
Joined Dec 19, 2007
2,918
Could you give us a little more detail? A schematic, a link to info on the PLC and the field device? My guess is that two transistors and three resistors, or a small MOSFET relay and two resistors would do it, but not knowing any more than I do now, I'll stop here.
Ken
Pich
Joined Mar 11, 2008
119
Usually a PLC will have a 24V source, if speed is not an issue you could use a 12 volt relay and 24 v on the contacts or a solid state relay as mentioned earlier.
Goerge99
Joined Mar 18, 2008
3
The PLC range I'm using is a Delta PLC, the module has a sink and source function, depending on how it is wired.
I'm trying to source on the PLC.
There is a sketch attached.
The diode Number: IN4007
Treat the lamp in the sketch as a input to the PLC.
Thanks
KMoffett
Joined Dec 19, 2007
2,918
"Delta PLC" is not enough info...do you have a model #? "Sink" and "Source" are usually output functions, not input. Though this might refer to pulling the input high or low. The manual should clear this up if we can get to it. :)
Ken
techroomt
Joined May 19, 2004
198
realize that you connect a sourcing field device to a sinking input, and a sinking field device to a sourcing input. quite a plc if an input channel can be user customized to either function. regardless, use a relay (12vdc coil and 24vdc power source) interfaced to the plc input. and as mr. pich has mentioned, you will have additional propogation delay of the relay, and some plc's (usually micro's) source a 24vdc for field device inputs, some don't.
KMoffett
Joined Dec 19, 2007
2,918
technroomt,
I assume that the terminology is for industrial controllers. Since that is not my field, do you have a link or reference that I can persue?
Ken
mrmeval
Joined Jun 30, 2006
833
If you have or can acquire the manual for it you'll probably find it can handle a range of values. Some PLCs can be set for what voltage you want it to detect.
KMoffett
Joined Dec 19, 2007
2,918
techroomt,
Thanks, I'll check it out. I don't know what I would do without the internet...haunt libraries like I used to do, I guess. ;)
Ken
