Thanks folks again for this analysis. As I said I haven't looked into the devices in detail yet but if we assume each circuit will support 25 led (so 1 on each side of the path every 2 metres, assume each led is 1w so 50w total (might not need this many - depends on how much light is cast by each led) then without a relay both pir would need to support this. I have seen 12v pir devices that say they can support 100w so is a relay strictly necessary? I guess it could cost less overall so probably a good thing and also improve lifespan. Thanks again!
