Hi all,
got a short enquiry. I’ve got these premade 3mm LEDs that already have the resistor soldered to run under 12v DC instead of 3v.
This is a flashing LED and the circuit is pretty simple and already has a green constant LED, red flashing and pink flashing.
On the circuit there is a motor that when it operates, the pink flashing Led should turn on and start flashing. The Green LED is constantly on to show that the circuit has power and it works all the time.
Problem is when the motor has some load, the pink LED stops flashing or flashes randomly. I’ve found this issue with the pink LEDs, flashing and non flashing. Should be something to do with the colour?
Wherever I connect the pink LED on the circuit, the same issue occurs. Even controlled by a relay, different power supply, regulated or unregulated, more amps etc.
Could someone shed some light on how I could fix this?
Regards,
Steve
Regards,
Steve
