MisterBill2
- Joined Jan 23, 2018
- 28,597
The fan mentioned uses 13 watts power, which tells me that it is quite a bit more than a normal "computer fan" would be.Why not just use a 12 volt computer type fan ?
Les.
It is also an induction motor type, and so it might possibly need more than just a simple "H-bridge" to drive it effectively, given that a simple bridge will deliver a square wave. Certainly a scheme with a bit of "dead time" between alternating pulses of opposite polarity is possible, and theadding a suitable capacitor across the motor winding to resonate with the drive frequency.
So at this point an input from somebody who has driven a small induction motor with some sort of inverter is what is needed. And that is not me.
As for isolation and the panic about how the fan must be isolated, consider that 12 volts from a battery system is not a shock hazard. I quote: " I’ve converted all my home lighting circuits to 12V DC to take advantage of solar power I’m gradually installing. " So there is no need to think that this is a mains powered rectified DC system that poses such a POTENTIAL shock hazard.
