12v DC photocell switch that powers one circuit at day and another at night?
Daniel J Clark
Joined May 16, 2016
6
Does anyone know of a component - preferably weatherproof - that will power one 12v DC 65w load during the day, and switch to a different 12v 65w load at night, never powering both at once?
mcgyvr
Joined Oct 15, 2009
5,394
Do you actually need a power source or just a device to do some switching?
A photocell and relay could easily..
Quick search turned up this which would do it but would require a 24V source to power it and a separate photocell.. But it seems that it could easily do the switching that you want..
They may have a 12V version or there may be another out there..
https://www.hubbell.com/hubbellcont.../Daylight-Harvesting-Controls/DLCPCC/p/220890
I would think there are SPDT photocells out there though.. or as stated just get a photocell and a form C (SPDT) relay and put it into a watertight box..
Reloadron
Joined Jan 15, 2015
7,977
The heart of it would be a photocell or any number of light sensors. You want to switch between two 12 VDC 65 Watt loads which is 12 VDC at about 6 Amps so allowing headroom 12 VDC at 10 Amps. Hard to make suggestions without knowing your location but a simple Google of 12 VDC Photocell will bring up a few dozen hits like those on Amazon. Use the output to drive a simple SPDT (Single Pole Double Throw 12 VDC automotive relay. The photocell can be a simple Dawn to Dusk and some versions allow setting how much light when switching takes place. Pretty much a matter of exactly what you want and the exact application.
Additionally you can buy the relay with a pre wired socket, like this one.
Ron
sghioto
Joined Dec 31, 2017
8,763
Or something like this on Ebay you could put in a sealed enclosure. DC 12V Photoelectric Switch Sensor Relay Module 50mmx25mm w 2 Cable LW
SG
MaxHeadRoom
Joined Jul 18, 2013
30,881
If using two units and only one can be on it would be preferable to use a contact on each relay for interlock, as there could be some overlap when two sensors are detecting a light source, or lack of.
Also can there be a dead period or must one or the other be on at any given time?
Max.
28,561
Another option, much simpler, would be to have a simple switch to switch on the fountain when you wish to see it, and switch it off the rest of the time.
28,561
How did you know it was a fountain?
Ron
It was mentioned someplace at one point, earlier during the discussion. I think about the time that it was explained that we were not discussing 220 volt mains power switching. The suggestion that I had initially offered would have been a very simple and easy way to do it if the power were 220 volt mains. 12 volts from a battery system makes it more complex.
Reloadron
Joined Jan 15, 2015
7,977
Thanks as I was wondering, fountain? What fountain? :)
Ropn
ebeowulf17
Joined Aug 12, 2014
3,307
Are you referring to this thread?
https://forum.allaboutcircuits.com/threads/digital-switch-between-devices-please-help.147172/
If so, different thread and different user name.
