12v Circuit Question
NoobCircuits17
Joined Jan 10, 2021
24
Okay I think I’m having a issue with the connection at the batteries. Now I’m getting 14.8v on my new batteries and 13.0v on my test batteries. I’ll reconnect everything and give it a try.
NoobCircuits17
Joined Jan 10, 2021
24
okay I tried it again and the relay will not kick over so I’m thinking that the bms cannot take the draw that the really is pulling. So if that’s the case I think a 5v 4 pin relay will work
sghioto
Joined Dec 31, 2017
8,763
That can't be true unless the BMS is defective.
Takes this one step at a time.
Connect the battery pack directly to the W1209 with out the BMS or Solar Panel connected and see if the W1209 works.
NoobCircuits17
Joined Jan 10, 2021
24
Power from batteries to W1209 is good it engages the relay.
Powerr from the BMS output terminals 8.8volts to the W1209 and it’s not engaging the relay.
The light comes on when indicating the relay should be engaged but no power to the fan. I’ve contacting the seller of the BMS so I’ll hopefully see a replacement sent. Last is there alternative setup for the same application of the solar and batteries ?
NoobCircuits17
Joined Jan 10, 2021
24
The W1209 says it will operate between 6 and 12 volts. Maybe it's the fan that will not operate on 8.8volts.
Maybe so..... If worse comes to worst I could swap the relay out for a lower 5v relay. Just a guess. The BMS seller said he would be shipping a newer upgraded one to replace this one so I’ll check that too.
NoobCircuits17
Joined Jan 10, 2021
24
After short time of debating if the new BMS cannot supply the full 12v as needed I feel that a simple solution of just switching the 12v relay on the W1209 board with a 5v relay will fix that issue. Thank you all who posted and thank you sghioto for your help. When the new parts come in I’ll post a update.
NoobCircuits17
Joined Jan 10, 2021
24
Okay long awaited news I just received my new bms and I’m receiving the same output of voltage as the last bms (9.8v). So my solution is to replace the 12v relay with the 5v relay and that solves that problem. Now I had another question maybe someone can help me with where to connect a battery capacity indicator on the existing wiring diagram ? Thanks again all.
NoobCircuits17
Joined Jan 10, 2021
24
Okay so I’ve done some testing of my circuit found some issues that need to be fixed. The battery holder has a bad connection causing my voltage to be 9.8voots at the 14.8v terminal of the bms. So I need to fix that to get the full voltage to my thermostat. I had a question regarding the battery indicator and where it connects, if anyone can help me but I think the positive lead goes to the 14.8v terminal of the bms and the negative terminal for the battery holder is that correct ?
Audioguru again
Joined Oct 21, 2019
6,826
Does the BMS have translation errors? it says 40A and 80A peak which will blowup the battery cells to kingdom-come.
A cell at 3.7V is barely charged, 4.2V is a full charge after its charging current has dropped.
