i am trying to add a charger jack in my 12v system.
it may seem obvious what i should be doing but i just want to make sure i get it right and don't damage anything.
i have a 12v battery running two motors which are controlled by a rocker switch. (on/off)
the battery has a volt meter connected directly to monitor the health of the battery.
where should i connect the charging jack in this circuit ?
does it just connect direct to the battery terminal ?
do i have to do anything else to protect the circuit ?
i have attached a basic circuit drawing but with 9v battery as that's all th program had.
thanks in advance
thanks in advance
