12 To 220 Dc To Ac Inverter Problem
Status
Not open for further replies.
reza gharbavi
Joined May 21, 2017
11
DickCappels
Joined Aug 21, 2008
10,661
What is it that you find unsatisfactory about your circuit?
The transformer is key to the operation of the circuit.What are you using as the transformer?
R!f@@
Joined Apr 2, 2009
10,014
You expect to supply 12v 50A with those puny wires and expect it to work.
By the way...where is the transistor collector connections ?
You need to mount the transistors on a heatsink and connect wires to the sink.
You need to isolate the transistors from the sink if you do not wish to blow them up.
Build it properly and then ask questions. Go through your work a few times to see where you might have gone wrong.
Good luck.
R!f@@
Joined Apr 2, 2009
10,014
Oh by the way.
who designed that circuit.
A 500W inverter with a 10A fuse.
That fuse will blow even the lighter loads
Status
