110V and 220V adapter
fchfghf
Joined Jan 31, 2020
I have an electronic device who works with 110V but I'm in EU. Is it a goos idea to replace the full bridge rectifier by a simple diode to have a half wave rectifier to have about 103V?
dl324
Joined Mar 30, 2015
18,521
Welcome to AAC!
You should be more specific. You're referring to 110VAC and 220VAC. 110V would be taken to mean 100VDC.
No. A half wave rectifier means you'd only be using half of the cycle. It won't reduce the voltage.
The proper way is to use a step down transformer. They're commonly available. To find an appropriate one, you need to know the power used by the device.
shortbus
Joined Sep 30, 2009
10,049
Is this device like a computer? Many things now days have a switch mode power supply (SMPS) built into them, with either a switch on them near the cord, or they automatically change internally to the proper mains voltage.
