110V 50Hz Mini Heat Gun to 220V Compliant
Aleksandr Gonzales
Joined Jan 15, 2016
28
Good day!
I received a 110V 50Hz 300W Mini Heat Gun. It was my fault that I didn't see that it is rated at 110V. Our standard here is 220V. The heat generated by the gun is uncontrollable, maybe because I have plugged it in a 220V outlet. So I opened the heat gun an see that it only has few components.
1. Switch
2. Motor
3. 2W10 Bridge Rectifier
4. Heat Element
I was wondering if I can make it compliant with 220V getting parts from our hair dryer with a source selector (110V or 230V). I opened it up and there are many components:
1. Carli MPX40 240V Capacitor with a 1M Ohm Resistor
2. 6A4 MBE Diode
3. Heating Element (Thicker)
4. Diodes (1N5395)
5. Motor with Capacitors
Or can I swap the heating element to make it thicker?
KeithWalker
Joined Jul 10, 2017
3,628
Replace the bridge rectifier with a single 600V 5A rectifier diode. The motor and heating element will then only receive 110V RMS.
Ian0
Joined Aug 7, 2020
13,317
Unfortunately not.
It will receive 155V rms (220V/√2)
Double the voltage and the load will dissipate four times the power, add a half-wave rectifier and it will only do so for half the time.
Power will be double what it should be.
KeithWalker
Joined Jul 10, 2017
3,628
Unfortunately not.
Yes, I stand corrected. It must have been an age related mental hiccough!
J Power Electronics 10
Similar threads
110V AC/DC TO 13.5 V DC
