Hi, I'd like a 10kW 48V DC instant water heater. Just like this Stiebel-Eltron product but 48V DC. I'm pretty sure this doesn't exist as a commercial product, but could someone build me one?
KWh and KW are two different things. You need to know how much current your battery can provide.My power supply is a 57kWh lithium battery bank, so 10kW is less than 0.2C, so should be fine (lithium batteries can usually safely be discharged at about 0.4C).
> Are you competent to work with high power?
Nope! But will get some help from someone who is before turning this system on.
I know what C means, do you know what KWh means? It's not a different way of spelling KW.The "C" rating of a battery means the power that would be provided if the battery was fully drained in one hour - e.g. 1C = 57kW, and 0.2C = 11.4kW for this battery:
https://batteryuniversity.com/learn/article/what_is_the_c_rate
The actual ability for the battery to deliver current is more complex than a simple C rating. You need to know things like ESR which will limit the delivery and derating due to heating. That simple conversion is just an estimate.Yes, but 1C for a 57kWh battery is 57kW... right?
The battery may be able to handle it, though I am not sure about long term. Another consideration is that you will need to run something like 2/0 AWG wire to the heating element. If you were running 480V you'd only need 20A and the conductors would be a much more reasonable size.These are the cells I'm using... This spec page lists 0.5C as the max discharge current:
https://www.evlithium.com/hot-lithium-battery/946.html
... so I'm confident that the battery pack I'm using will easily supply 10kW for the duration that it's needed...
Here's some chat about someone with basically the same battery pack as mine (4 x 1P16S) talking about internal resistance and heating... sounds like it's not a big issue: https://diysolarforum.com/threads/heat-build-up-at-0-125c-discharge-rate.13907/
Those cells you link to have a 280Ah capacity (at 0.5C). Running them at 200A will give just over an hour's worth of current at rated voltage - assuming you get everything together...These are the cells I'm using... This spec page lists 0.5C as the max discharge current:
https://www.amazon.com/DERNORD-Foldback-Element-Immersion-Electric/dp/B018S4AO8WNo idea... Was looking for suggestions really!
The system is composed of four independent 1P16S batteries in parallel... So each battery provides 52A.Those cells you link to have a 280Ah capacity (at 0.5C). Running them at 200A will give just over an hour's worth of current at rated voltage - assuming you get everything together...
M | IGBT >10kw dc to ac inverter | Power Electronics | 14 | |
I | Need Guidance in designing of LC Low Pass Filter for 10KW Auto transformer based Power Supply | Power Electronics | 4 | |
10KW power supply | Power Electronics | 3 | ||
N | Designing a PFC for 10kW+ Loads | Power Electronics | 1 | |
S | 10KW inverter design. | Power Electronics | 5 |
by Don Wilcher
by Jeff Child
