I am still looking for help in this thread - upgrading an immersion heater to 48V... hopefully that won't be so difficult!
You're in a room full of nerds who tend towards pessimism. It is not that complicated. 48V heaters exist, as do 36V, 24V, 12V, and many other voltages. Here's a 1,500W 48V heater.OK everyone, thanks for all you help. It seems like this will be too difficult / expensive so I'm cancelling this part of the project.
blow themselves apart is a wee bit dramatic, as long as the conductors are rated and all the joints are tight, 200A is straightforward ( we do this at work all the time ) - the trickiest bit might be the joint from the conductor to the heating element at 200ADC - as this has additional heating from the elements as well as the DC current ( 1 milli-ohm = 40 watts ) . This is why a higher voltage AC approach with lower currents ( 10kW 230Vac = 44A, 0.001 ohm = 2 watts ) is often preferred by the professionals.10kW at 48V is complicated. At that current, connections can blow themselves apart if there's too much resistance. Or they could just heat up and cause a fire... If you go this route, you need someone who's certified for high power applications.
400-800A switchboards are bread and butter. Hell, 2-6kA, 480V services happen all the time in medium industry. Takes a lot of very controllable heat to run an injection molding machine or twelve. You can push thousands of amps through a single multi-barrel lug - as long as the equipment, the termination and the wire itself are all listed and sized for the same temperature rating. If either one is too small it will get hot.blow themselves apart is a wee bit dramatic, as long as the conductors are rated and all the joints are tight, 200A is straightforward ( we do this at work all the time ) - the trickiest bit might be the joint from the conductor to the heating element at 200ADC - as this has additional heating from the elements as well as the DC current ( 1 milli-ohm = 40 watts ) . This is why a higher voltage AC approach with lower currents ( 10kW 230Vac = 44A, 0.001 ohm = 2 watts ) is often preferred by the professionals.
The Chezch system uses thermo-relay. As soon T increases over some 70 or 80 C the heating is closed by relay.the other issue for "instantaneous" hot water systems is that the heater must be powered down VERY QUICKLY if the flow stops or reduces drastically
Aaaah, from here You got the 48 Volts! Firstly, the Photovoltaic efficiency is around 20-22% (only!!). Secondly, the solar heat accumulator efficiency is about 50%. Thus. it is very trashy to use photovoltaics for heating the water. But if, then first complication is that if factory makes a wrong device and someone dies, the death is not Your fault. Whilst if You Yourself wound a heater and someone was electrized to the death, Your rest of the life will be spent in the prison. Thus You SHOULD keep on fabricated products with proper warranty, and that means 220 or 380 V versions and nothing else. Ah ya, probably America have something local for 110V. And 48->110V may re-shape any appropriate boost-up type of SMPS.Or just use a photovoltaic inverter to obtain
| Thread starter | Similar threads | Forum | Replies | Date |
| N | Instant Vortex Air Fryer Works but Fails to Heat After Transformer Burnout and Brief 220V Connection | Technical Repair | 13 |
