100w led on drone with maybe 12v battery ?
Alec_t
Joined Sep 17, 2013
15,132
also should i buy any power booster to boost voltage
It's no good boosting voltage if the LED has inbuilt current control and is designed/rated for a specific voltage. Go above that and the LED will have a short but merry life. And are you allowing for the weight of the booster:rolleyes:.
tcmtech
Joined Nov 4, 2013
2,867
the reasons for this build is i have a farm and i require this to do little work at night so this will help thanks
So you work for like 5 - 10 minutes after dark while staying in one spot or while using a multi channel drone remote with both hands while moving? o_O
Personally when I work after dark I usually either use lights in the yard or on equipment or if in a more remote areas a LED headband light. :p
a Rob
Joined May 14, 2017
151
i am the controller and i have other members of the family doing the work , it gets pitch black so we had to come up with a temporary solution , we have alot of cleaning to do and feeding and more stuff so this is needed will be good help.
thanks
Reloadron
Joined Jan 15, 2015
7,893
Just keep in mind, no matter what you are doing or who is doing your time aloft is limited and the more light the shorter the flight time. If you want spots or floods you may want to look at "Daymaker" lamps as used on motorcycles or motorcycle "spot" lamps. These are all bright LED lamps and most have a light temperature around 600K (Daylight). Regardless of what you use the time will be limited as to getting much done. On a farm for night work people around here use tractors or farm vehicles with light bars designed for night work on farmlands.
Ron
mcgyvr
Joined Oct 15, 2009
5,394
Ron
But daddy I can mount a siren on it too and round up the cattle from the field all while sitting here on a bale of hay with my feet up..
"Smack... Thud... POW...."
Not when I'm alive son... Get to work like a real man..
