100w led on drone with maybe 12v battery ?
a Rob
Joined May 14, 2017
151
time 2:45
if u can kindly look at the led he has i will super love to have that on my drone , i need your expert advise how i can archive this please anybody.
cheap or expensive i dont mind please find a root to make this , what ready made pcb are they that i can buy of ebay that can get me this done by simple just connecting up all wires , or maybe little soldering i dont mind ,main thing is powering up this thing and not puting lot of wight on drone , he has done it maybe we can to with your expert advise.
i hav dji phantom 3 advanced , if u can se on youtube phantom 3 advanced lift test u can se how much it can lift so please help me cheers.
mcgyvr
Joined Oct 15, 2009
5,394
10 x 10W LEDs + Power Supply (batteries+ constant current LED driver) + heatsink..
Almost looks like each has its own constant current driver mounted above it..
Simple..
Learn the basics of how an LED is intended to be powered first..
And I guarantee that thing is scorching/scalding hot after about 5-10 minutes of use without a heatsink..
How much weight can your drone carry?
Electronics are better/more fun when you actually learn vs just having the project handed to you..
mcgyvr
Joined Oct 15, 2009
5,394
Reloadron
Joined Jan 15, 2015
7,978
These are the specifications for your drone. I suggest you read and more important understand them. The lights in the video he mentions 100 Watts powered by a 1800 mAh power supply which he has attached to the drone in the video. I suggest you play the video over and over again till you understand what is going on. I really believe we now have members who likely know your drone better than you. It has been suggested you learn about weight? Your drone has a payload weight and I suggest you figure out what it is. The greater the payload the shorter the flight time until the thing will not get off the ground. I have no clue what your payload max can be and apparently neither do you and you need to start with the basics. You want a bright 12 Volt LED? Start looking at motorcycle spot lights.
Ron
Reloadron
Joined Jan 15, 2015
7,978
Watts are how we express power. The Voltage * The Current = Power. There are other formulas but that will do for now. So a 100 watt LED (lamp or anything) powered by 12 Volts would be 100 / 12 = 8.333 Amps. The power is expressed in watts so manipulate the formula, you can always solve for the third when we have two out of three. Next start to understand how in theory a 1800 mAh battery can deliver 1,800 mA or 1.8 Amps for one hour. That would be 3.6 Amps for 30 min. or 7.2 Amps for 15 min. and finally 14.4 Amps for 7.5 min. That is in theory. Real life is different. I think in the video he mentions the 1,800 mAh power supply (battery) and he mentions how much time he gets with his 100 Watt LED. There is much, much more to this and as before I suggest the shallow end of the pool.
Ron
a Rob
Joined May 14, 2017
151
am in united kingdom, greater manchester and also lol few days ago terrorist attacked 19 dead.
can look at this light will this be ideal and bright also
RamaD
Joined Dec 4, 2009
328
Most appropriate question.
12V 7.2AH battery can just about give 30 minutes or less. That too on a full charge.
LiPo batteries for the same weighs less.
100W LEDs could give you about 5 tubelights of 4", just to get a feel of the light.
Sensacell
Joined Jun 19, 2012
3,789
It occurs to me that...
1) a driver like the ILD6070 would be good for increasing the power conversion efficiency, longer run time, lighter batteries.
2) using a bit of the prop-wash airflow would allow much smaller and lighter heat sinks.
Driving high power LED's without a heat sink is a good way to kill them rapidly.
tcmtech
Joined Nov 4, 2013
2,867
Given this and your other threads I have a very strong suspicion you are doing your damnedest to try and turn you drone into some sort of flying nuisance/annoyance which will ultimately just lead to the quicker banning of drones for everyone.
I can't imagine fro what gainful reason a person needs a car horn or a 100 watts worth of LED flood lights on a drone for.
If the 100 watts of floodlights doesn't pan out what's next? A set of high powered airport landing strip strobes? Saw blades? Firearms? :rolleyes:
mcgyvr
Joined Oct 15, 2009
5,394
wil it be same power as shown on the video sir
I showed you a 100W LED.. The video stated 100W LED.. There was no mention of lumens that I saw but in general a 100W LED will be similar to another 100W LED in output..
So buy what I linked.. Then attach it to a 12V battery and strap that all to your drone and you are done..
BUT... Your drone (assuming phantom 3) can only carry an extra .3kg so you will need to go with lightweight batteries and strip that LED down to its absolute basic components (just like in the video)..
Just do it and be done and enjoy the learning experience..
You have also been given the math to work out the needs of the battery as far as capacity goes..
So you are all good to go.. Digest whats been told to you and decide the direction you want to head..
a Rob
Joined May 14, 2017
151
can u tell me or show me the link your mentioning ? i cant se it please give me the link to 100w led u mention
mcgyvr
Joined Oct 15, 2009
5,394
See post #4 or just click here..
http://www.ebay.com/itm/21-inch-100...ash=item3f77e6e365:g:ccQAAOSwYXVYzJ34&vxp=mtr
One just like that is what the guy used in the video.. He just removed the circuit board/electronics from the housing..
There are many like that.. Just search for "offroad LED light" on ebay or whatever and buy one you like.. All are 12VDC powered and easily attached to a 12V battery
a Rob
Joined May 14, 2017
151
hi thanks so much for the reply also look at this video the very first scene the lights also will this also work
i purcashed
http://www.ebay.co.uk/itm/231255725670?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
will this battery cover it ? also should i buy any power booster to boost voltage
check time from start to 1:24 other leds what type are they the ones u has on near each props they looks beter also
the reasons for this build is i have a farm and i require this to do little work at night so this will help thanks
